Is it worth it to get Geforce4 Ti4200 if i only have a LCD monitor?
Joecheng
101
I currently using a Geforce2 GTS 32 MB card from Asus .. . I'm thinking about upgrading to a Ti 4200 but i only have a 15 inch lcd monitor because of dorm space is too small . .. Is it worth it spend the 150 $?
ai42
3,653
What does the corrolation between a Graphics card upgrade and your TFT (LCD is Liquid crystal Display, but TFT is Thin Film Transfer which is what it actually is) monitor? I don't quite get your question, you are going to get a performance boost by upgrading but how does the monitor factor in?
mchammer187
9,114
if your monitor has DVI and the card you want has DVI than yes
if no DVI than you can at least run at 1024x768 w/ 4X FSAA and AF pretty well right?
i have a radeon 8500 on my 15" LCD and it suits it fine though I'm looking at a 20" LCD before I get any video card upgrade
edit: AI42 15" LCD will only do 1024x768 max so he's wondering if it is worth it to get the GF4 if he can only run a max of 1024x768
John
Moderator Emeritus<br>Elite Member
4
15" LCD's run optimally at 1024x768 . IMHO there is need to drop the cash if you monitor can't scale up in resolution to take advantage of the video card. This is also one reason I still have a GF3 on my secondary rig using a 15" LCD.
Joecheng
101
Sorry for the confusion, thanks mchammer for clarifying that for me . . . So what would be a nice upgrade that would still be nice on my lcd? 8500le?
mchammer187
9,114
yeah i'd say stick with GF3 or a Radeon 8500 LE
jamie2833
396
i am thinking the same thing, i just got a 15'' TFT screen, pretty good as well with a 25ms response time i dont notice any of the blurring any more as my eyes have got used to it,i love it!
i think it will be worth getting a geforce 4 with a TFt monitor as when games like unreal tournament 2003 comes out which is pretty soon you wont be able to get good frame rates at higher resolutions anyway, i say get one, a geforce 4 will probably be better with UT2003 but you can pick up a radeon 8500 for under 100 dollars nowadays on the forums
