I just bought another Motherboard with onboard SATA support (Gigabyte K8NSNXP, S754, NF3 Chipset, there are (2) SATA plugs controlled by the NF3 250 chipset, and (2) SATA plugs controlled by a Sil3512 controller), for my latest build/upgrade. I am seriously considering a SATA HD this time. I would like to stress right off the bat that I am not interested in a RAID array. I understand the basics of RAID, and I just don't want to be bothered with it at this time.
My basic question is: Is it worth it for me to go with a SATA HD?
I don't want to get a Raptor (well, not considering their prices) right away, since I am currently on a budget and this CPU/Mobo/HS upgrade is turning into a new build. At $80 the SATA drive I am looking at is affordable and large enough to help store some DVD ISO's.
I do have a Seagate 120GB HD (PATA 8MB) that I was going to use, but I am wondering about any performance gains to be had by using SATA. I remember reading up on SATA when it first came out. The review I read basically showed that the performance was pretty even with PATA 100/133 drives. The reviewer stated that while the SATA drive didn't offer substantial improvement over a PATA drive right now, it should be considered that AGP 1X didn't offer a huge performance gain over PCI when it came out. Only in later offerings (2x, etc..) were the gains of the new standard able to be seen.
The drive that I would most likely get would have to be a Western Digital Caviar SE 160GB SATA HD . It is the only one I can get quickly and locally (I plan on finishing this build later on today). Can anyone tell me whether there would be a substantial performance gain in using that drive over a Seagate 120GB 8MB PATA? I should mention that I do game on my system and I also burn DVD's.
-Thanks in advance for any help/info you can give me, Ken
BTW:
Rounding out the system will be a A64 3000+, XP-120, 2X512 Patriot 533 DDR, and a 6800GT @ Ultra speeds. I play BF2, Burn DVD's in addition to basic web surfing, etc...
Which controller would be best? The 'NF3 250 chipset' or the 'Sil3512' controller?
IIRC isn't there a limitation (that's less then 160GB) on WinXP? The install disc I will be using includes SP1a.
BTW:
