Is it still crazy to scan 1000 magazines?
Page 58 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Aquaman
25,054
13
Yo Aquaman! Share with us your enlightened scanning knowledge!
I picked up an Epson GT-S50 duplex document scanner recently, but I'm having some trouble getting the file sizes down. Scanning a color book makes like a 150 - 600 meg file. If I optimize it, it gets smaller but looks terrible. Scanned ebooks available online are like 15 megs for 500 pages with color photos and look great...how the heck do they do that?! I've been tinkering with settings and various scanning programs, but I can't seem to find the right mix of quality vs. file size for PDF output. What do you suggest?
I'm not really familiar with that scanner. The only thing I could suggest is to fiddle with the scanning resolution. For my magazines it's set at 150dpi...... which is acceptable for my purposes.
Are you scanning into PDF? I don't have any experience doing that because my old scanner did not have that option.
Cheers,
Aquaman
Kaido
Feb 14, 2004
48,688
5,443
Cheers,
Aquaman
Ah, what are you scanning to - image files?
rudeguy
47,351
14
61
I just started ripping/reripping my 1000+ disc DVD collection.
After 1 day I am starting to think that I am crazy.
Have 4 computers going at once, 31 down, 969 to go.
so you can only do 8 per day, per PC?
Funny. I can rip a whole DVD to ISO at high quality in under 15 minutes.
I think we have caught you in yet another lie.
Kaido
Feb 14, 2004
48,688
5,443
Yes....... jpegs. I'll be converting to PDF's.
Cheers,
Aquaman
I'll let you know what my final workflow is. I just picked up Acrobat X this week and I'm REALLY enjoying the scanning features. It's basically a 2-shot deal: the initial ingest covers deskew, OCR, optimization, etc. (all done automatically via presets in one pass) and then you can apply a custom crop across the entire document (trims the edges nicely, so ultimately a simple 2-step process). The files sizes are much more reasonable OOTB as well - they still need some work to get a tad bit smaller (which is what I'm tinkering with), but overall it's looking really good. I think Acrobat X is going to be my one-stop solution for scanning documents & books to PDF!
SonnyDaze
6,867
So Aquaman how many new PCs have you built/bought since you started this? Has new advances in PC technology changed the way you are doing your scanning or your progress?
Kaido
Feb 14, 2004
48,688
5,443
Screenshot of the basic settings I'm using in Acrobat X right now:
http://i.imgur.com/r7ZS9.jpg
Took about 5 minutes - from start to finish - to scan in a 62-page color cookbook (to a final PDF) that came with my George Foreman or something, one of those 4 x 9" spiral-bound thingies (took the paper cutter to the edges). Scanning on the Epson GT-S50 was pretty quick, then I had it run through the PDF import (deskew, OCR, etc.) then did a manual crop and applied to all the pages (after rotating a few that were off - but the auto-rotate did a pretty good job overall).
Entire document came out to 1.97 megs - 62 searchable pages, in color. Very nice!! Still have some optimization to do - dithering could be improved a bit & the de-skew feature needs some tweaking - but I'm much closer to the bullseye now than before :thumbsup:
Aquaman
25,054
13
I am still using the same PC 11 years old Athlon XP 1600+. Original Scanner died though and My USB's have kind of crapped out....... maybe time for a new PC.
Cheers,
Aquaman
AgaBoogaBoo
26,108
He is scanning at a lower rate than he is getting new magazines. Kind of like USA is spending way more than it makes :biggrin:
No way... that's impossible. You might be implying that there's $50k of debt on each citizen... but that would be ludicrous.
