Yep. Instead of screwing the grill to the fan use the clips to hold it on. I'm doing just that and it works fine. I'll see if I can find a pic...
Pic 1: an old pic of Collective, showing an 80mm fan with grill mounted on an SK6+ Pic 2: close-up of Asmodeus' CPU cooler, an SK7 with an 80mm fan and grill
Dunno about the the SK-7, but I have the SLK-800, and I have the grille screwed in. The clips don't even touch the grille, so it's all good. Looks nifty, too.
They should give you an idea. The clips sort of hang over the grille, but they don't make solid contact with it, so using the screws was a necessity in my case.
