Is it safe to put some kind of mesh over an AC unit? Details inside...
Night201
3,697
I was just sitting here editing some videos when all of a sudden a huge wasp flew in through my A/C unit. Luckily I had some bee spray!
My question is this. To prevent this from happening again or anything like it, is it safe to put some kind of meshy material over the vents outside to prevent insects from flying in to my apartment?
Lounatik
1,845
Do you have the vent knob open? Some a/c's do not have a screen on the vent door opening(though most should). Besides that, I'd take the front cover off of the a/c and see if you can see daylight anywhere inside there. I'd also check to see if the unit is sealed around the wall or window. Bugs cant just "come in" through the a/c without a hole being present for them to wiggle through.
I was an a/c repairman for about 8 years and have a decent amount of experience in Florida with window units and Ive seen hornet nests built up in the backside of some units and the bugs couldnt get in the house because the unit had a good seal.
One more thing: Be careful about putting anything, like a screen , in front of your a/c. It could force cold air back onto your thermostat and cause the unit to short cycle. Meaning, the thermostat senses it is cold enough and turns off prematurely and then turns back on real quick because it got a faulty reading.Not good for the circuit breaker or your a/c.
Hope this helps.
Edit: After reading your message again, I think you are talking about the back of the unit? If so, I wouldnt recommend it. Your a/c was designed for the maximum airflow from the case. If you do anything to interrupt the airflow, you lessen the heat removing capacity of the condensing coils out back. Less airflow=less heat transfer=less cooling in your room. Not to mention the stress on the compressor and the dreaded circuit breaker.
Peace
Lounatik
Night201
3,697
I don't plan on putting it on the back side. It seems to be small enough, but there are vents on the left, top, and right side. I'll see if I can get a picture later. I don't have my camera right now.
Lounatik
1,845
If anything has ever been done.. its also been done by an ATOT member. :p
True.True.
Night201, if you take the cover off of the a/c can you see any light coming from around the edges? If you do, that could be the problem. If you do see it, go to Home Depot or Lowe's and get some foam weather seal to seal up the cracks.
Peace
Lounatik
