is it right for 2100 to run over 2100 spec! screenys!
Twista
9,646
Im not saying its stable in prime95 because for what i do with my pc it has never rebooted or dumped memory.
1 example
MDE
13,199
If it works it works. Might that be Crucial PC2100? That stuff seems to be ungodly overclocking RAM considering its labeled PC2100.
zephyrprime
7,512
I've been thinking that all high density pc2100 being produced nowadays is actually pc2700. After all, new process generations raise CPU clock speeds so it should raise ram clock speeds also.
Twista
9,646
no way! One stick is $40 NR pny from compusa and the other is $27 from some cheap store from pricewatch. I know that i couldn't run seti even know i dont. Because i know prime95 fails with-in 1 sec maybe.
New screeny. Is this ok or good or bad. Ram is about 166mhz
