Is it possible to use a s478 P3 Mobile 1.2GHz chip in a desktop mobo?
DotheDamnTHing
2,795
Intels site lists it as :
SL5CL 1.20 GHz 133 MHz 0.13 micron FPA1 512 KB 478 pin PPGA
so is it possible to use it in a 478 mobo?
Philippine Mango
5,594
What kind of friggen P3 is 478 pins?? P3s are 370pins and FYI it aint goanna happen period, even in a P3 board...
bluestrobe
2,033
It?s almost the same socket as a P4 except one pin so no it won't work in socket 478 boards. I have seen some specialty motherboards using in SSF systems that could use the mobile P3 but I can't find them on the net at the moment. To the noob's there is a big difference between the mobile and Socket 370 P3. The Mobile P3 looks like a P4 without the heat spreader.
DotheDamnTHing
2,795
you got it ribbon13...i just wanted to know if you could use a desktop mobo (p4) with a BIOS update of some sort that could use the P3 Mobile chips?
bluestrobe
2,033
Originally posted by: DotheDamnTHing
lol what a noobular
My thoughts exactly. Probably asking about 550mhz Cirix P4's for his socket 7 motherboard in another thread.
VirtualLarry
56,572
10,208
Even if that really was a S478 P3 CPU... don't the P4's use an mPGA (micro-PGA) S478? So why does that chart list PPGA? In fact, even the Tualatim P3 desktop chips, are FCPGA or FCPGA2. What the heck is that thing? I think we need pictures of it. (found some) Hmm. It is a S478 PPGA P3 chip. Learn something new every day.
Edit 2: Thank tcsenter, that makes the most sense - that the CPU in question is a Pentium-M. I hadn't considered that. I was wondering what all those extra pins on a "classic" P3 CPU would have been used for.. it's not like the Tualatin chips needed extra power/ground pins, they were already remarkable low-power as it is. I still don't think that the S478 PPGA package in the picture that I linked to, looks like an mPGA to me - that looks like a standard PPGA, just with some more pins.
imported_whatever
2,019
Originally posted by: GOSHARKS
ive never heard of a 478pin p3...
In fact there are 517 pin P3/Ms too. The 133FSB ones are 478, the 100FSB ones are 517 (not positive that it is the exact pin count, could be off by a few either way)
tcsenter
18,896
553
Intel Mobile Pentium III Processor - M (note the "M") based on .13µ process technology and Intel Mobile Celeron are available with 478-pins and in fact are physically pin-compatible with mPGA-478 sockets used for Desktop Pentium 4 processors. This is what Intel has to say:
The new Intel® Pentium® 4 processor uses a 478-pin package while the mobile Pentium III processor in the FC-PGA package uses a 478-pin package. While physically, you can insert a Pentium 4 processor into a mobile Pentium III processor-M notebook or a mobile Intel Celeron® processor notebook and you can insert a mobile Pentium III processor-M or a mobile Intel Celeron processor based on .13 micron process technology into a desktop Pentium 4 processor system, the two type of processors are not electrically compatible and it will damage the processors and/or the system if you do. In addition, this can void your warranty for your notebook and processor.
I purchased a PC Chips motherboard with Intel 845GV chipset for $20 that supports 400MHz & 533MHz mPGA-478 Intel P4 and Celeron processors. With PIII-M processors going for as little as $30, I may pick one up and give it a try. If it kills the motherboard or CPU, no big loss. ;)
495 pin PPGA, and it is available in both 100MHz and 133MHz FSB. e.g. sSpec Number SL3TQ 650MHz
Jan 31, 2002
40,819
Wow, look at all the no0bs in here. ;)
tcsenter, save yourself the trouble and the board. Check the pinouts if you need confirmation, but it's gonna go boom. :p
- M4H
