Is it possible to use a network card in dos?
hymy
535
I need to install a ghost image to a computer. I created it using my network. It turned out to be to big for burning on to cd. Is there any way I can map a network drive using dos?
netgear fa310tx
Windogg
Look for DOS drivers on the installation disk or at the Netgear website. I currently use Intel and 3COM cards at work in DOS modes for disk imaging just like you.
Windogg
hymy
535
I think I might be in over my head. Well I'd like to be using disk imaging in dos. But I can't find dos drivers. I found something: Dos driver for ndis. I don't know what it is though.
hymy
535
Obenton,
Man I Love you, ;).
You wouldn't beleive the complex crap i been through. I tried for 3 days to do this. On ars they got into a pissing contest over who could do it better, but wouldn't tell me how to do it. And some guy said it'd be easier to move the hardrives around. Somebody told me to get dr-dos, but it would have cost $99.
I even searched pretty thoroughly and couldn't find anything. You are the tha man.
