Is it possible to transfer data between 2 PCs using a USB port?
Arkitech
I have an old laptop that I need to copy files to and I can't find the network dongle, fortunately it does have a USB port but I don't know how to transfer anything through it. Anyone out there know how to do something like this?
you can literally plug a USB cable into each PC?
it cant be that freaking easy.
i was thinking USB network adatper....
Uh..it is. Never used a parallel port to transfer data back in the day??
usb network adaptor
link coming...
Or do this...it'll be much easier.
you can get a thing that you can plug into the floppy drive on both pc's 🙂
Um a floppy disk? 😕 😛
no, a floppy data transfer cable.
you drag things to the floppy and they appear in a folder on pc #2
usb network adaptor
link coming...
How fast is the transfer?
Nope Sneakernet
What's the transfer rate for parallel and serial transfers?
Nope Sneakernet
I've done this... You needed a Laplink cable. I think that a parallel cconnection could achieve 300 kbps/sec.
No, it is NOT that simple. Doing that will likely fry your motherboard.
They make cables specifically for this, regular USB cables will NOT work.
Viper GTS
Nope Sneakernet
300 kilobits per second per second. 😛
Viper GTS
oops, yeah...basically it's a crossover USB cable. Got to get one of those since they carry power over USB!
usb network adaptor
link coming...
not sure, limited by the floppy cables
