Is it possible to remove the pins from 4-pin and other power connectors?
duragezic
11,234
4
At my new job I generally make cables and wiring harnesses all day and whatnot. Pretty exciting huh! So I ordered a new compy ugprade, and in another month or so I'm going to get a new case and high quality fans for a quiet, cool, and efficient system. Now I see people buying PSUs with sleeved cables, but I figure I could sleeve them myself. Theres a couple types and sizes of sleeving for cables that I'd imagine I could get a few feet of.
But to slip the sleeving over, I'd need to remove the pins from the plastic connectors from all the wires coming from the PSU. Is there anyway to remove these pins? I put on all types of connectors at work and usually they just require a little screwdriver to flip up a plastic piece so that the pins can be pulled out after they are locked in place (for the times I forget to slip something on then put on the connector then realize it!). But I don't see that these pins can be removed from PSU connectors. Any ideas? I have one from a fan that appears loose and puills out, but I dont know how that happened and its only one pin./
Rommels
290
And please for the love of all things holy stop the infection that is the word compy...
duragezic
11,234
4
Sweet man, thanks for the info and link. Looks like I'll be pulling out the PSU and making some measurements later today. I can get heatshrink tubing there as well but I'm not too sure if I got a heatgun here. Well I'll just use electrical tape if I can't use a lighter or something to shrink it.
And I didn't know compy was a bad infection. You should check out OT, there is some real dumb sayings that people are just obsessed with there. People purposely replacing every 'the' with 'teh' is retarded.
GalvanizedYankee
6,986
Jab-Tech.com and performance-pcs.com carry good sleeving. The cheap $10 kits from SVC are not to be used by me again.
Two weeks ago Harbor Freight had their low-end heat gun on sale (on-line) for $9.95. It has settings for 600 and 1100 watts. Good quality for lite-duty use. I have one.
Do a search of the Cases&Cooling Forum for sleeving. There is much good info to be had.
...Galvanized
dqniel
650
DON'T use electrical tape. I've learned from previous experiences. It makes everything all sticky should you ever need to take off the sleeving in the future. Find a heat gun (whether purchased or borrowed) and use heatshrink tubing.
AndrewZorn
384
yeah get real heatshrink, usuall comes in sleeving kits,
invest in the tool, it took me like 2hrs just to sleeve one chain with a paperclip,
you can use a hot glue gun or hairdryer instead of a specialized heat gun
Jiggz
4,329
While you're at it you might want to replace your Molex with This
It makes connecting and disconnecting easier. Not to mention the cute colors!
Rommels
290
OMG YES, I got them on mine and I only wonder what took so long to think of them.
What was I thinking, I should ahev thought of this.
