is it possible to o'clock a voodoo 3 without needing xtra fans/cooling?
rogue1979
3,062
Voodoo 3's run hot at stock speed. If you just put a small 40mm fan on the heatsink you should be able to get 175MHz. Some will go as high as 190-200. You need to install your 3dfx tools and V3 overclock.
Rand
11,071
The V3 2000's were excellent overclockers, indeed they did run how but many 200o's could hit the 166/166 of the V3 3000 without any added cooling.
acidvoodoo
2,972
<< The V3 2000's were excellent overclockers, indeed they did run how but many 200o's could hit the 166/166 of the V3 3000 without any added cooling. >>
ok i'll try it and if it starts to make the screen act strange i'll change back
