roynany Member Jan 24, 2021 68 5 81 May 2, 2023 #1 Is it possible to make a "DisplayPort 1.4a" connection to HDMI 2.1? on all its components? Is the next generation of video cards with DisplayPort 2.1 Will it be possible to convert to HDMI 2.1?
jarablue Member May 3, 2004 120 20 81 Dec 18, 2023 #2 Yes you can connect DP to HDMI. I am sure DP next gen will connect fine with hdmi 2.1, an older spec. Should be a non issue. As long as the ports and cable support the speed. No problem.
