Is it possible to have a network without an Internet Connection?
50
2,717
I have a dlink router but had to cancel my DSL subscription and now the router isn't working. I can't setup my network without a connection it seems. I need this connection so I can remotely print from my laptop. Do I have to buy a switch or something else?
RebateMonger
11,586
A D-Link router does not need an Internet connection to act as a switch and DHCP server to support a network
1) Reset your router to the default factory configuration by holding down the reset pin for ten seconds while the router is powered up.
2) Connect all your PCs to the LAN Ethernet connectors (usually, there are four of them) on the router. Do not connect anything to the single WAN connector.
3) Ensure that all your PCs are set to automatically receive an IP address, subnet mask, default gateway, and DNS server in their TCP/IP properties settings.
4) Reboot all your PCs.
Your network should now be functional as before, with each PC receiving its IP address via DHCP from the D-Link router. All PCs will be on the same subnet and should be able to talk to each other through the built-in switch in the router.
eplebnista
24,123
36
:cool:
