Hi there,
I have my cable modem in a room upstairs; next to it is my Linksys W5RTG Wireless Router. This router is plugged directly into the cable modem. I've got a couple computers connected to it (using wireless connections, and such). My question is, is it possible to introduce another router (same wireless router model), into the basement environment, and somehow get the two routers to join together using the one cable modem. Obviously the second router wouldn't be directly plugged into the cable modem, so i'm not sure if it will work.
The reason i want to do this is because i recently moved into the place bringing along my 3 computers which used to be hardwired into the router. I do not have PCI wireless NIC's and as much as possible, i would i like to save some cash, by utilizing what i already have.
So what i'm basically asking is if this is possible:
CABLE MODEM (Upstairs bedroom)
Wireless Router 1 (Upstairs bedroom, plugged directly to the cable modem)
Wireless Router 2 (Basement, wanting to utilize the internet connection that Router one has).
Thank you in advance for the answers.
