Is it possible to have 2 IPs on 1 machine?
Cooky
1,408
Due to some routing issues, I have to dial into a server (which is not on the company LAN) through modem. But at the same time I need to update a file that's on the LAN.
Now my question is: is it possible to obtain 2 IPs simultaneously, 1 being the dial-up and the other the LAN.
My guts tells me the answer is a NO but is there anyway around this problem??
easternerd
if you are using a vpn connection and dialing on the public internet then the server needs to be configured to give you an ipaddress for the remote area subnet . This is the usual norm .
But i donno how your network is configured ... please provide some more information please.
sswingle
7,183
45
There isn't a problem at all. Your machine can have many IP addresses at once. Your dialup modem gets one when you log on, and each NIC you have in your system can have its own IP.
MysticLlama
1,003
And just to make things really confusing, each NIC can actually have multiple IPs, and even on multiple subnets...
As far as dial-up / LAN it should already give you both IPs. Your NIC IP won't go away just because you get an IP from the dial-up provider. (Unless you have some security software or something that drops your LAN connection)
Cooky
1,408
Indeed that's very confusing...I got more info then I needed but thanks for all of your help!! I'll go ahead and try next Monday.
Oh I'm not sure how network is configured or if we have VPN at all...but I'll see how it goes next week.
Cooky
1,408
ok so I did get 2 IPs - 1 for the dialup modem and 1 for the LAN. But when I try to access the Internet, the dialup connection is used instead of the LAN. How can I tell my laptop to use the LAN?? The 28.8K dialup is too darn slow...
rcracerx
347
In your web browser option you need to tell it to use your LAN connection and not to use your Dial Up connection. In IE it is Tools/Option/Connections.
Rc
ToxicWaste
115
You need to go into the advanced tcp/ip properties on your dial up connection and uncheck the box that says "Use default gateway on remote network".
Garion
2,331
7
Doing this is definitely considerd a Bad Idea (tm). If you have anybody who manages to hack into your machine from the Internet, you've just opened up the door to your company's whole network.
If you have to do it, just make VERY sure that you have some kind of firewall enabled on your machine, as a minimum layer of protection. Still not recommended, however.
Best bet: Dial in, do what you need to do for work, disconnect and then do what you need to on the Internet.
- G
