Capitalizt
Banned
Sup folks, I downloaded one of those shareware disk cleaning programs to delete useless/duplicate files. After running a complete scan and seleting everything, I rebooted and my start button/programs are missing. I can still access everything through the "my computer" icon and everything seems to work fine, but I believe the program deleted some critical system files that I need to access the start button.
My question is...First of all, has anyone had this problem and fixed it?
If not, can I use an XP Pro disk that I have to do a "repair install" on a Dell System that came with XP Home pre installed? I do have the emergency Dell system restore disks but those will basically reformat the drive and cause me to lose everything...something I want to avoid!
Is it possible to use an XP pro disk to restore the original system files on my XP Home system, without erasing all of my programs and documents?
