Is it possible to create your own surround sound speaker system?
sman789
Banned
May 6, 2003
1,038
Say out of like leftover speakers and subs????
and you can hook up each set to the connectors of a mobo with 5.1/6.1
squidman
643
Of course! Use your imagination!
What youll need: either active speakers (i.e with built in amp) or a standalone amp with speakers coonected to it. Heck, you can even connect your pc to a stereo, as long as it has l/r inputs. My PC has audio branching (ie LOTS of cables). It has a signal splitter (cuz i connected it to 2 sorround sound systems), one 5.1 connection goes to my room aiwa surround sound system (never bought gay computer speakers in my life! If iu have a stereo, why not connect to it, for better sound, and to save??!), and the other 5.1 goes to the other room with big-ass surround sound system (for music listening).
Tell me bout your config, what speakers/equipment you got! ill help with cable selection and like!
ed21x
5,411
8
im pretty sure most sound cards have three connectors: one for the two front channels/bass, one for the two rear ones, and one for center. so yeah, just use those three as an output source to any speaker with a built in amp, and you're good to go.
sman789
Banned
May 6, 2003
1,038
right now i do have my pc audio output goin to my stereo.....but both are from the last millenium, before everything had 5.1 audio
I'm going a new PC soon and the mobo will have 5.1 or 6.1, it has like 3 or 4 outputs like one for front-right/left, subwoofer.....so i would just need a standalone amp and do a cable cutting job to get it all together
(i have plenty of old speaker boxes i wanna use and some subs)
Goi
6,772
7
Its a good idea, but it might turn out to be pretty expensive. If its well designed and constructed though, the sound quality should be great.
