- May 21, 2003
- 101
- 0
- 71
Hey all... i have access to a speaker system and i was wondering if i could use my portable mp3 player as a source. The speaker system uses 2 1/4" plugs, however on ebay i found converters that will split my 1/8" female jack on the portable player into two 1/4" jacks.
I am not TOO concerned about sound quality... but i am wondering if this is bad for my portable player. It has a line-out setting, but i dunno how i would be able to control the volume using the setting. Do the larger speaker systems require a stronger signal (and hence draw more power), or will the built in amplifiers take care of it? I am assuming the speakers do not draw power from the source unit... am i wrong to make this assumption? The speakers are pretty large (i dont know much about speaker systems, but they look like 2 big guitar amps, and the amps my bro uses do not draw power from the guitar).
CLIFFS:
- want to connect portable mp3 player to large speaker system
- speakers use 1/4" jacks
- using 1/8" -> 2 1/4" converter
- wondering if this will create problems with my portable (power requirements)
CLIFFS:
