Is it possible to burn an MPEG-1 stream on a DVD?
FishTankX
2,738
My friend was wondering. He has a ton of video and wants to use it on his home entertainment system.
One theory he had is burning an MPEG1 stream onto a DVD and hoping that his set top unit recognized it.
Is such a thing even possible?
Excelsior
19,047
18
Get TMPGEnc http://www.tmpgenc.net
You can use its projecty wizard (file - project wizard) to use a dvd template and create a dvd encoded file that you can use something like ulead dvd workshop to burn to a dvd-r!
Spicedaddy
2,305
77
you don't have to reencode... Just burn the MPEG-1 files as a VCD on the DVD-R media.
That way you fit a lot more video. Converting MPEG-1 to MPEG-2 (DVD format) is useless. It won't look better and will waste space.
Spicedaddy
2,305
77
Originally posted by: oldfart
From reading the post, I dont think the video is in MPEG1 format.
Yeah, I read too fast, thought he said the videos were mpeg-1. If they're decent quality AVI, it would be better to make a real DVD...
FishTankX
2,738
Well my question is with a DVD burner is it possible to burn a VCD type template onto a DVD and fit 8 hours of video onto a DVD, which his DVD player will recognize?
FishTankX
2,738
BTW, he is content with VCD quality video for casual viewing, and this is exactly what this is for. No 'Video quality' concerns beyond VCD quality.
SearchMaster
7,791
114
Here's the specific link on DVDRHelp.com showing how to burn an MPEG-1 file onto DVD-R.
As stated above, you'll need to use TMPGEnc to convert from AVI to MPEG-1, then use the above link to burn to DVD. Good luck!
