Is it possible to build a off grid cam with a raspberry pi pico that takes a picture every few hours?
thedighubs
167
17
41
good day dear friends :)
well - not very sure if this goes into right "sub"
plz set me straight if i am wrong here
what is aimed: Is it possible to build a off grid cam with a raspberry pi pico that takes a picture every few hours
my winter project is to create a off-grid cam that sends data to my pi (/that is local).
off grid - projects are challenges:
well i think that in the area of Raspberry Pi-off-grid projects, power management plays a crucial role. power management seems to be important and i guess that all is not just about keeping the off-grid-device up and running; No - ist much much more. i think that it's all about ensuring optimal performance, stability, and longevity of the off-grid-project.
that said: well my Friends told me that i can do this with an ESP32-CAM. that is prettty cheap and damned simple. it is besides this also low power and comes with a allready established design and software. But i wonder if it is not possible to do this with a Zero or Pico;)
i am Pretty sure that i need to install a library or app for the photo taking.
probably we can get motion or I think there's even a camera app included in most pi distributions - so this would be nice.
even better if the Pi has a camera. very important - to make sure that the Pi has a battery.
what if i have really long times between recharges - well if so then i should have a look into different battery technology or even a solar panel that charges a battery every day for the Pi to drain.
what do you recommend - how to set up the solar charging circuits.
many thanks for any and all help.
ps. i am so happy to be part of this forum ;)
turtile
633
315
I saw a few presentations recently where researchers used a Raspberry Pi, a camera, and a motion sensor to take photos of moving wildlife. I don't know the specifics, but you should be able to find the software online. You can build a box around a large lithium battery so that it doesn't get wet.
sdifox
100,210
17,891
Why RPI pico instead of esp32-cam? What exactly are you gaining? You'll need to add a wifi shield to pi for you to connect to wifi.
13,801
Are you planning to send this out somewhere or does it stay local 100%? If local only, you could just use a trail cam.
I have a cheap trail cam right on my off grid property gate and it takes AA batteries and lasts for weeks. (have not really tested any longer, I swap the batteries and SD card each time I go). It's a temp setup as I don't have any fixed power source there yet to run a proper CCTV setup.
