Is it possible that my inverter is attached to my LCD?
Finns14
1,731
Ok so before I order my replace LCD for my XPS m1530 I wanted to make sure I checked I could get the old LCD out and check the s/n etc. As I was taking it out I was able to remove LCD but it seems I couldn't remove the inverter with out some serious effort to the point where I don't think it was supposed to come off. Is it possible this is how it should be? Also I can't seem to find a good pic of new LCDs to see if they have the inverter attached. Thanks.
Emulex
9,759
the inverter is usually wrapped in foil. obviously LED backlit screens don't have inverters only CFL.
i've never seen one unshielded. its a high power generator so be careful and be sure to wrap it back up unless you want to make an emitter(EMI)
MadScientist
2,183
63
Your inverter is not part of the LCD screen but attached to a bracket on the LCD screen. The inverter is wrapped in what looks like an orange anti-static plastic.
A small screw on the bracket that holds the inverter must be removed first, then you can slide the inverter out of the bracket.
Here's how: http://www.insidemylaptop.com/replace-lcd-screen-inverter-board-dell-xps-m1530-laptop/
I just replaced a LCD screen on my Inspiron 9300. It had an inverter bracket that looked similar to your XPS M1530. Unless you buy a screen from Dell (mucho expensive) most replacement screens will not come with an inverter (unless specified or used) or a bracket. The inverter bracket on the original screen is permanently attached and can not be removed. Not sure if it's soldered or riveted on, but it's not re-usable. I used the original inverter with the new screen and it sits in the space where the old bracket was. No big deal, you can't see it, the bezel keeps it secure, and the new screen looks great.
Best place to find a replacement screen is eBay: http://shop.ebay.com/?_from=R40&_trksid=p3907.m570.l1312&_nkw=Dell+XPS+M1530+screen&_sacat=See-All-Categories
Before you order one make sure it's the same type and resolution as the orginal. Mine was a WUXGA, glossy, 1920 x 1200 resolution, CCFL backlight.
Finns14
1,731
Thanks thats a great guide although I think the inverter is riveted to the bracket I'm going to try and remove it. Also how I double check the res? I believe its the same as urs but will my laptop boot and post with out a lcd attached I had it connected to a monitor.
MadScientist
2,183
63
As the guide states the inverter might be glued into the bracket so it may take a little force to get it out. If you can not get it out then you will have to get a new inverter. http://shop.ebay.com/i.html?_nkw=Dell+XPS+M1530+inverter&_sacat=0&_trksid=p3286.m270.l1313&_odkw=Dell+XPS+M1530+screen&_osacat=0
The guide also states that you have to transfer the mounting brackets from the old to new screen. Is the inverter bracket part of those or separate? If separate then you may be able to bend back the bracket with a pair of needle nose pliers to free the inverter. On my original screen there were 2 screw down brackets on the top that were permanently attached to the screen. My new screen did not have these. I could only attach it to the hinge brackets on either side. It felt secure so I didn't worry about the top brackets.
You can check your system configuration by going here: http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs and entering your service tag number. The service tag is a 5-7 alphanumeric code on a white tag on the bottom of the laptop.
Then under Product Support on the left side of the page, click on System Configuration. Under Original System Configuration and Parts it should state what type of Liquid Crystal Display you have.
Mine is a WideUltra Extended Graphics Array or WUXGA
Here's a good site that explains the types of LCD screens and resolutions: http://www.lcds4less.com/faq.shtml
Your laptop should boot and post to an external monitor without the LCD screen attached.
There's a few screens on eBay that come fully assembled with the inverter, inverter bracket, and mounting brackets.
WSXGA screen
http://cgi.ebay.com/DELL-Vostro-1500-XPS-M1530-15-4-WSXGA-LCD-SCREEN-A-OEM-/230529930615?pt=LH_DefaultDomain_0&hash=item35aca79577#ht_4551wt_1137
WUXGA screens
http://cgi.ebay.com/New-DELL-XPS-M1530-15-4-LCD-Screen-TrueLife-1920x1200-/220653889937?pt=LH_DefaultDomain_0&hash=item335fff2991#ht_1695wt_911
http://cgi.ebay.com/NEW-OEM-DELL-XPS-M1530-15-4-LCD-SCREEN-WUXGA-GLOSSY-/320575567123?pt=LH_DefaultDomain_0&hash=item4aa3caf513#ht_1739wt_911
Finns14
1,731
WSXGA screen
WUXGA screens
Unbelieveably helpful thnaks
