I built a new PC with a P6X58D-E 1366 mobo new DRR3-ram with a i7-950 cpu I kept the case & PSU and my fanless vid card. It's louder when I'm booting up and about within a min the sound is very low you can't hear it unless you get your head to the side of the case. The sound it's self changes tone it's not always sound the same close but not exactly the same.
At first I thought it was a bad Heatsink and fan but after I googled my ''P6X58D-E noise'' and it is the Mobo and read a few topics/post about the same problem people were having with the same Mobo one guy even replaced with same Mobo and had the same problem. People suggested to others with the problem to just disable C1E Support in the bios, what this does is it reduces your multiplier and voltage to your cpu when you aren't doing something CPU intensive. The same people said that it either reduced the noise or eliminated altogether.
I was going to return the cpu/HSF but after reading this I don't think I will it must be the Mobo. The sound is almost not noticable but I felt that I should investgate anyway. I'm going to disable C1E Support cause I want to save energy whenever I can.
I wanted ask do you think the board making that sound or whatever is causing it could cause damage in the long term ? Or maybe I shouldn't worry about it and the board nor any components will be damged in anyway ?
Do you think I might of misdiagnosed the problem ?
Or do you think it really is the fan ? The only way I could check if it's the fan would be power off the PC disconnect fan power from Mobo so the cpu fan does not start when I turn on the PC and see if it's the fan or not. The thing is about this test it could damage my CPU, would it ?
thanks
thanks
