Is it possible for two different CPU on dual motherboard?
Cheapest
435
OK, I have the Intel L440GX+ DUAL CPU Motherboard (AA721242-008). Is it possible to put a PIII 700 and PIII 450 CPU? I cannot find any where mention this?
Megatomic
20,127
Neither Win2K nor WinXP support asymmetric multiprocessing so I'd guess no at least at the OS level. Most dual PIII boards I've seen and used required the same CPUs, too.
crypt0n1c
11
Its worth a try maybe they will both just run at 450MHz but from what I have heard both cpu's need to be identical in a SMP setup.
mechBgon
Oct 31, 1999
30,699
440GX is more commonly associated with the PentiumII Xeon and Pentium3 Xeon. Are you positive that this is, in fact, a dual-Slot1 board, and not a dual-Slot2 board?
(and while I think it isn't impossible to run two different-speed CPUs, it would be pretty foolhardy)
Cheapest
435
OK, if it can't what about could it be use with the same speed (say PIII 700M) but different types say step 1 and 2? Let question differently, is it all we need is same speed will qualify for the broad? (Can you use Comprimise and Catman CPU with the same 500M?) Any one try?
mechBgon
Oct 31, 1999
30,699
Big picture: a dual P3 500 will be trounced by a used $20 1GHz Duron in most situations (gaming, etc). Don't throw too much money down this hole. ;)
And running different CPUs of the same speed is not a great plan. If you have two with the same speed, same core, and no more than one stepping apart, then you're playing by The Rules.
Cheapest
435
Isn't some game good for dual 500MB CPU because of the dynamic of multi-thread benifit of the two CPU instead of one 1GB CPU???
