I'm t hinking about adding another receiver and maybe a third one later on. Can I just use those cheapo radio shack coaxial splitters to split the wires from the dish to each receiver? Or do I need something specific and where can i get it? Thanks.
Originally posted by: ThaGrandCow
I work at DishNetwork so I could be wrong about DirecTV, but with our stuff you can't use a splitter, you need to get a switch otherwise your signal quality degrades so much you won't get anything. Call up DirecTV and ask them what you need. It's probably going to cost you about $50 for the switch or so.
Originally posted by: jfall
I have DTV. All I have is 1 dish with a dual LNB. One wire goes from one output to 1 receiver, the other to the other receiver. Simple as that. Two seperate receivers on one dish.. watch whatever you want on either one
