it's this one
https://m.costco.com/Samsung-40"-Class-(40.0"-Diag.)-4K-Ultra-HD-LED-LCD-TV-UN40KU6290D.product.100319924.html
It looks like it does 4:4:4 @ 60 hz, so it's probably reasonable:
https://hardforum.com/threads/40-sa...st-buy-or-265-with-25-200-amex-offer.1917765/
I've been using a 49" LG for over two years now, some of the best $800 I've ever spent on PC gear. It does have it's drawbacks (primarily how windows handles the display powering off), but if you can get a 40" 4k for ~$300 you're not likely to be disappointed.
Just make sure you have an HDMI 2.0 video card.
Viper GTS
im having the exact same issue with my samsung 4k with nvida card and win7 pro! whenever i turn the monitor back on, all the application windows are squished down to about 640x480. i would have to manually resize them back to whatever i want. seems windows 7 refuses to remember their locations and sizes. nobody seem to have a fix for this for 4k TV used as a monitor. i tried updating win10 and the same thing happens, so i imaged the drive back to win7.![]()
I think it was the "flat screen" craze that took off. For some reason, people preferred the look of 1024x768 LCD panels over 1200x1600 CRT sitting on their desk. And then "High Definition" became everything to consumers (still not an actual improvement over what CRT's did)I've been toying with this for a long time. Seems 4K TVs are more common and cheaper than monitors. Only issue is I think it would be too big physically. Though I guess you can look at it like what a 4 monitor setup would be like.
I hate that computer monitors are so behind in terms of resolution though. How the hell did it happen where TVs are ahead? Even PHONES are ahead especially if you consider DPI.
Im using a 40" Vizio as a computer monitor, and its works decently well.
Plus 4:2:2 subsampling on most UHDTVs.. Using my cheap 43" Sceptre 4K UHDTV (3840x2160 @ 60Hz) and dual 27" Yamakasi 2703 LCDs (5120x1440) with Windows 10 works fine via display port (R9 290X crossfire) to HDMI 2.0.Additionally, TVs just don't have the viewing angle, color uniformity, sufficient gamut, and proper white point for serious graphics work.
If you play games and watch netflix, they work great.
And finally, Windows scaling, even with 10, is just plain horrible. Nowhere near that of OSX.
Tried it and at 40" I find the screen is too big for average viewing distance and the PPI too low at 3840x2160. 36" would be the ideal size and 8K resolution of course.
it's this one
