Is it OK to mount a Hard Drive vertically or on a slant?
Macro2
4,874
Someone brought me a computer to repair an I noticed the back of the HD hits the motherboard/IDE connector on the IDE cable and they just have the back two screws missing and it just kind of resting on a slant. I'm thinking maybe it's better to hand the thing vertically?
Is there a problem with HDs on a slant or vertically mounted?
Thanks, Mac
NokiaDude
3,966
Hard drives can be mounted vertically or horizontally. As long as you don't move the hard drive it should be okay slanted. I personally would fix it so it wouldn't slant.
beatle
5,661
No problem. Mount it however you want as long as its secure.
Kaieye
I just mounted a hard drive upside down. I hope I don't have any issues soon but it seems to be working fine. This is not for any mission critical use and is used strictly for recreational purposes.
thorin
Yup as long as it can't move while in operation then it should be fine.
Thorin
dullard
25,813
4,357
I had a hard drive dangling from the IDE cable and power cable for about 2 months. The case wasn't on and it was just dangling on the side, where anyone could bump it at any time. Nothing happened. Of course if the data was important, or if the HD was someone elses, I wouldn't suggest doing that.
Slogun
2,587
Lian-Li cases mount the hard drives so they are sitting on their side.
It's never been a problem for me.
Markfw
May 16, 2002
27,032
15,979
Thorin
From what I have read, any horizaontal or vertical is OK, per the bearings design, but NOT on anything other than 0 or 90 degrees in any orientation. In other words NO slants.
Camofrog
177
mine are mounted vertically in front of the front fans (works well). just like every body else says as long as they dont move around while being used the are good to go in about any orientation.
thorin
Thorin
Ok perhaps I should clarify. I have no doubt whatsoever that if you mount it on a angle and then it fails that you'd be regected for RMA if you were silly enough to tell them how it was mounted. I also have no doubt that that's what most HD manuf's say in their manuals. However in practice over the years I'm saying from experience that it won't cause a problem.
Thorin
dullard
25,813
4,357
You gotta think about the real world. If that were true, then HDs would fail in any computer that has an old ricketty desk (ie not level). Or in old houses where the floor is starting to sag a bit. Basically, HDs are frequently in a small slant.
Baronz
588
Mount it best you can, just make sure it isn't going to fall. Worse thing for drives is sudden movement or hitting hard things while operational. I think they're tougher than people give them credit for...I've always moved my case around while the drive was reading and I've never had a drive fail on me yet, of course i don't do that with my newer drivers :)
Slogun
2,587
Probably true. I would not worry myself about a HD sitting on a slant myself.
I've had one dangling from an IDE cable in my server.
Markfw
May 16, 2002
27,032
15,979
Excuse me ! I think if I wanted to spend the time to lookup the white papers, it is within 5-10 degrees, but essentially level.
JBT
12,094
I had an old 40 gig 7200 rpm maxtor tillted a bit because I had a HDD cooler mounted on it but it didn't fit correctly in my old case, for about a year. I still use this HDD as my primary drive today works great its not tillted any more though.
What about lap top drives ? I barely ever have my lap top on a flat surface it is often tilted one way or another as well as when I leave my laptop on when carrying it between classes.
I think it is probably alright for them a bit but I doubt manufactures like it much.
sharkeeper
10,886
Always consult with the manufacturer with a special case scenario.
Generally, fixed disks are mounted horizonally with the spindle motor bottom facing toward the source of gravity. If they are mounted perpendicular to the source of gravity then standard practice is to make the spindle motor shaft exactly 90 degrees perpendicular to the "flux lines" of the source.
Cheers!
thorin
Of course that's what they say. They have to cover their butts.
Thorin
hans007
20,212
18
Thanks, Mac
if you have 2 screws on one side, thats kinda bad. sometimes a screw can break and a piece will stay stuck in the drive. its ebtter to have one screw on each side, diagonal from each other.
a slant is not supposed to be good, but i doubt it really matters. but to be safe, go vertical or horizontal
chorner
134
Guys, its usually NOT OK to have your HDD's on a slant (that is, an angle other than level, or even 90deg to level).
Think about gravity, the motor, and the bearings. Tilting 90deg, or not having your drive rotating level will reduce the lifespan of 1) the bearings and 2) the motor itself. This is because the wear will naturally be at its greatest at its nearest point to the center of Earth, causing unequal wear on the bearings and motors.
Think of something that rides on a bushings. Tilt it off center, and notice the wear. Now tilt it level again, and notice the wobble to whatever side and degree you tilted it on.
Think about =====[]===== a small wheel on a straight cylinder running level. It will have even wear, and hence not wobble as much left and right over time; which would be a cause of the "clank" sound in old HDD's where the read head actually whacks the spinning platter.
Same goes for items that run on bearings; although to a lesser extent.
