i did a pentium 4 build and noticed the motherboard had that 2nd power connector that pentium 4 CPU's have-- that 4 pin deal....
a previous pentium 4 MB i used didn't have this connector...
anyway, the case isn't pentium 4 type-- the power supply doesn't have that 4 pin connector...
windows XP installed just fine-- have used the computer a little bit-- no problems.
anyway, is it ok to leave that 4 pin connector on the motherboard unplugged, so to speak? or should i go out and get a power supply (or pentium 4 approved case) that has that 4 pin power supply to hook to that connector on the MB?
thanks
thanks
