Originally posted by: spidey07
It's normal.
You'll learn to control it by how much air you have in your lungs. With your lungs full you should float just barely. You'll sink when you let some out, you sink faster if you let it all out.
When scuba diving you use this all the time to control your buoyancy.
When my lungs are full of air, as described above, I float, but a few inches under the surface of the water. Basically the best I can do is just barely not sink.
So you are really skinny I take it?
You should be able to do a dead mans float. Fill your lungs with air, face down into the water, arms out...and you'll float. When you let air out you'll start to sink.
Ever think about swimming classes? that will teach you how to breathe.
Yeah, I'm pretty skinny. I can definitely do the dead man's float, but it doesn't do me any good 😛 When I do this float the skin on my back barely break the water's surface.
I took swimming lessons once, and I even took and passed the swimming test, but it was tough and I know for a fact that I'm not good enough to save my own life if I, say, capsized without a life jacket in the middle of a small lake. Swimming just tires me out very quickly.
If I try to swim with my head above the water all the time, like doggy paddle of the frog style, I get too tired and going below the water's surface within probably 30 feet. What I usually do is spend most of my time underwater, torpedo style and flapping my legs, and push for the surface only when I need a breath, because pushing above the surface is what tires me out the most.
EDIT: If there were waves, even moderate waves, I'd probably be screwed.
