Is it harmful to over fill your engin with oil?
scorpmatt
7,040
98
too much oil is bad, too little oil is bad, its gotta be just right, just like every other fluid in the engine
radioouman
8,632
a half liter isn't going to make a difference. Heck, i used to add an extra quart to my Saturn because it burned a quart in between oil changes. That way, I Didn't have to worry about adding one.
mordantmonkey
3,075
hmmm wonder why it burned oil? leaky seals, rings maybe?
PricklyPete
14,582
162
Um did you ever think of why it got that bad?
91TTZ
14,374
Because it's a Saturn and that problem is common. I have a Saturn. It burns oil.
91TTZ
14,374
I doubt a half quart will make any difference. Most engines have a range that they can use, which is from low to high. 300ZX's for instance had the same engine from 90-96, but Nissan changed the rated oil capacity sometime in the middle of production. The engine didn't change, they just figured that a little more was probably optimal.
It's not rocket science.
m2kewl
8,263
it's ok, the engine is not going fvck up. it's only half a litre, not like you dumped another whole litre in there!
what model car? if you just did this once, it's ok but don't make it a habit. just don't drain the entire oil pan and re-add. that's a waste of friggin good oil. ;)
dug777
24,778
4
i 'd fill it to 'full' but much more than that =why bother risking damage to your engine..?
Kalvin00
12,705
Originally posted by: PowerMac4Ever
you're gonna have to tear open the block and replace the piston rings you fried
:laugh:
Good thing the OP didn't blow the welds on the intake!
2cpuminimum
578
half a liter is ok. More than one extra liter--->>> foamy oil---->>low oil pressure---->>> engine failure
Zontor
530
Half a litre should be OK, most cars take 3.5 litres + .5 if you change the filter. What does the dipstick show?
