- Sep 5, 2000
- 9,173
- 6
- 81
what is the average life of a water heater?
Whoops, electric!
Bah, will the soldering never end!?
easy as pie
1. call a plumber
2. ask them to replace it
Extra hint: its even easier if you get the wife to stay home and wait for the plumber.
I did this last year and it was pretty easy. I highly recommend this approach. Extra hint: its even easier if you get the wife to stay home and wait for the plumber.
Whoops, electric!
Assuming there are shutoff valves for the hot and cold lines into the heater, just cut them after the valve, stick a shark bite in, and connect to your new water heater with copper or pex into the shark bite. Shouldn't take more than an hour, and no soldering necessary. Your new water heater will fail long before the shark bites do.
I thought about sharkbiting. I'll probably go that route since I dont yet know how to solder. I'm a little bit wary of sharkbites, but only because all the old plumber guys seem to rag on them.But thats true, the heater will fail before the sharkbites do.
For all the people telling me to replace the parts instead of the entire heater unless its leaking...well, i'm afraid it is leaking.
Appreciate all the advice guys!
