- Jan 6, 2001
- 2,041
- 0
- 0
Originally posted by: Sundog
It is one of the easiest thing you can do on a car besides put gas in.
It shouldn't take more than 5 min to change the air filter on your accord. The filter shouldn't cost more than $20 at the dealer.Originally posted by: TranceNation
i have honda accord 98, can i change it myself or do i need to bring it in?
Originally posted by: Pepsi90919
20 bucks wtf? i can get mine for like 2
You're making a big mistake if you buy the cheapest air filter that will fit in your airbox.
Your two primary filters are the only means of protection your engine has from the wear solid particles cause.
Buying a 2$ air filter for your 20,000$ car doesen't make very much sense.![]()
If you really want to save money, you could always buy a re-usable filter.
Not only are they reusable, but they provide much better efficency(read: more airflow, less particles) than a paper filter.
I was thinking of getting a HEPA air filter for my scooter engine. 0.3 micron filtration, baby.![]()
Riiiiight......Originally posted by: Skoorb
It's easy but you should get a K&N air filter for a 25% increase in horsepower!!!
Avoid all Fram products at any cost...their stuff is utter crap.Originally posted by: PsychoAndy
Skoorb: My autozone configuration printout
Air filters for this model:
STP: $6.49
Fram: $7.49
K&N: $47.99.
I went with door #1.
-PAB
