Is it enough power?
aniki
538
I want to order a ATI X850XT but Im a little concern because I have a shuttle Sb61G2 computer with a silentX pc40 250W PSU. I was wondering if it would have enough power to run a ATI X850 XT. Many claim that atleast 300W is necessary for current gen video cards.
I have 160 gig 7200 rpm HD with a Dual layer DVD drive in the comp. What do you think?Will it be alright? Im ordering it from the states to Japan so its a bit expensive if I have to send it back.. Also do you know if itll fit with out any modding?
Nick119
yeah you definately need a bit more than 250W.. I run a 500W PSU with a ATI X800XL, DVD-ROM, 250 GIG SATA WD, etc.. and its perfect. In your case, I would say get at LEAST 450W. The newer cards do indeed need a lot more power. Hope that helps!
Maximilian
12,604
15
No that 250w is not enough to run it safely, but the at least 450 watt is a tad overkill for the X850XT. a quality 350 watt psu would do it, personally i would get a 400watt simply so i have some headroom, but anything more than that is overkill. Either of these brands would be good: Antec/Seasonic/Enermax/Fortron/PCP&C
dguy6789
8,558
Remember, you are talking about a Shuttle PSU, not some normal one.
A Shuttle 240W is superior to an Antec Trupower 480.
aniki
538
Thanks for your replies. Seems like all of the X850XT have dual slot cooling. My shuttle has an agp and a pci slot. The PCI slot is available so it should make room for the dual slot cooler
imported_michaelpatrick33
2,364
Originally posted by: JEDIYoda
personallt I would get a PC Power & Cooling Turbo-Cool 1KW Power Supply or at the very least a TURBO-COOL® 850 SSI.
http://www.pcpowercooling.com/products/viewproduct.php?show=T85SSI
http://www.pcpowercooling.com/products/viewproduct.php?show=TC1KW
:laugh: We're not talking about Dualcore Prescott's here.
I would say that you look at the 12V rail on you PSU and tell us what is stated there. A 20,000 watt psu is not better than a 300 watt psu if it only has 1amp on each rail. If you 12V rail has 18+ amps I would say you are probably o.k.
