is it better(thermal compound)
jswjimmy
892
i got some thermal compound today my question is is it better that the stock thermal pad. the name of it removed all i know is its 10% silver, conductivity 7.5w/c-in2/w, resistance 0.06 c-in2/w. is it better?
bjc112
11,460
Anything is better than the thermal pad.
jswjimmy
892
i wish i could see the diod temp, stupid turbo 2. i had my xp1800 1530mhz oced to 1804 mhz with the stock hsf (therpad to) now im afrade to oc. lol if i put it on right i should be fine i will try to oc
jswjimmy
892
ok i found out what it is its Silver Grease its only a little better than silicone compound. its actualy worce than the thermal pad.
bjc112
11,460
Where are you getting that info?
Where did you get this Silver Grease?
jswjimmy
892
i got it from a computer shop in my town. i dont know where the info came from it was a test between all the thermal compounds
Jeff7181
18,368
11
I'd be reluctant to use no name brand thermal compounds. I'd use Radio Shack's white grease before I'd use some no name silver crap.
