Question Is Intel vPro/Ryzen PRO purely hardware based ?
FlameTail
If you take a vPro processor and normal processor, there are obviously going to be differences in the processor chip. But-
Are Intel vPro/ Ryzen PRO purely hardware based ? Or does it also include software components ( drivers etc... ) ?
Hardware based, according to AMD they use additional hardware based security.
The Hardware itself between a vPro/PRO SKU and a consumer part is identical. The difference is only between what is fused off or deactivated via Microcode, drivers etc.
Could you "unlock" a Pro version of your own CPU? I know that for ThreadRipper the Pro are repurposed EPYC processors with a factory overclock since they have the same specs(PCi Lanes and memory channel)
