Is Guinness lighter than light beer?
Kev
16,367
4
When you pour Guinness and a light beer into the same cup, the Guinness goes on top. Is it actually lighter, or is it just because the nitrogen is lighter than carbon?
ElFenix
102,393
8,552
you know that plastic ball in the guiness can that has the nitrogen in it? that is called a widget
BatmanNate
12,444
And was voted by the Britons to be the greatest invention of the last 40 years, bar none.
L
Lola
dunno about lighter, but sure tastes better!
Guinness is great!:beer:
Tom
if i wanted some nitorgem ohow do i get all of the other stuff out of it so i end up with just nitorgen ?
fatalbert
2,956
actually, in a black and tan, the Guinness is layered on top, but if left it will sink to the bottom, because it is more dense then Bass
or Harp if you make a half and half
TheBoyBlunder
5,742
Hard to argue with that.
mpitts
14,732
link
Fletcher found that as Guinness was poured into a glass, a large number of bubbles rose from the bottom, dragging liquid up with them. Because of the stout's viscosity, the center bubbles rose faster than the outer bubbles, then moved toward the outside of the glass and down. ''For small bubbles, the drag effect is larger than the buoyancy effect. The drag wins and the small bubbles get dragged down,'' he explained. Fletcher and Bergin have since traded research and believe the scientific data could have future applications in the brewing fermentation process.
Jan 18, 2001
14,465
black and tans are poured in a way that leaves the 2 beers layered. Usually a spoon is placed in the glass on top of the other beer to divert the flow in a more horizontal direction.
Howard
47,982
11
Buy some liquid nitrogen.
