- Oct 31, 1999
- 4,284
- 37
- 91
If a friend has a 1.4 tbird that will only do 1.55ghz @ 1.91v.
Load - cpu temps at 123f
Idle - Cpu Temp 107f
case temp around - 70f
It will boot & run fine a 2v / 1.6ghz but its overheats & locks @ 140f+ temps.
This is all done with a cpu multiplier @ 10.5 & FSB speeds of 133-153
Epox8k7a , Crucial pc2100 ddr, 512mb
Now, ive never got into watercooling but it sure seems that alot of people doing extreme overclocking are using
some sort of extreme cooling with great success.
Just looking at THIS link & THIS one , seems to prove that etreme cooling works or these guys are alot more than lucky buying cpus that overclock above the norm.
But we all know people can tell "fibs" so to speak. LOL
What are the realistic odds of water cooling getting this 1.4 to 1600 stable at 2v??
Or isnt overheating the problem here?
We consider anything over 50c / 120f the limit on heat for our setups.
Are we being too conservative with temps & its something else keeping his rig from being stable.
Anyone here ever try watercolling & DIDN'T think it was worth it??
