They're refering to file-level compression (NTFS's compression) not compressed archives (zip, cab, rar, tarball, etc.).Originally posted by: SUOrangeman
Compression also helps when moving a bunch of files and directories, as you can package everything as one file. Then you only have to transfer that one file.
-SUO
Originally posted by: spyordie007
Compression doesnt always mean slower access. For example there are a lot of "new" machines out there with fast processors and RAM but slow/obsolete hard disks. For these machines they could actually see a speed boost pulling from compressed files because it shifts some of the workload to the CPU and off the slow hard drive.
Not that I'm saying compression is a great thing, just using this as an example where it could mean faster access than leaving the files uncompressed.
Storage is cheap, but that doesnt always mean people upgrade it. I know a lot of people who upgrade other components but are still using 4year old drives so it might come in handy from time to time.
I guess my thought on it is "if you need it (and most people dont on a regular basis) than use it, otherwise leave it alone."
I'm missing something here...
I envision 2 identical PCs, with modern CPUs and adequate RAM, but with older hard drives like you described. Are you saying that accessing a compressed file would be measurably faster than the uncompressed one? This is counterintuitive to me; decompression would add overhead to the process, even though the net effect would be negligable because of fast CPU and RAM.
Unless... do you mean that less data would be pulled/accessed from the HDD with the compressed file? I.e. the slow hard drive (bottleneck) would be involved less in the operation?
With that same logic, though, and given that decompression is no chore at all for modern CPUs and fast RAM, why isn't compression the way to go because the HDD is still the bottleneck of the modern PC?
Very eager to have an explanation.
I thought that too.
Now imagine you have one file that is text. Say it's 100megs. You compress it and it gets 50% compression and now it's 50megs.
You have enough memory to hold the entire file in cache once it's read from the disk, and enough to decompress it, too.
You have a older drive that is only able to do 25MB/s. You cpu can decompress the file at a maximum rate of 40MB/s.
It will take about 2-3 seconds to read the compressed file from the harddrive. It would take 4 seconds to read the uncompressed file from the harddrive.
You see in this case the cpu and memory is plenty powerfull. The harddrive is the bottle neck and compression works to force more information thru that bottleneck then what would normally be possible.
The reason you don't want compression on a modern machine is because of data integrety.
Compression works by removing data from a file and storing it a encoded form.
Like if I had a file like this:
AAABAAAAAAAAAAAAABBBBAAAAAA
I could go like this
3AB13A4B6A
Then I could save it like that.
If the file corrupts into something like this:
3ABC3AB6A
and that would decompress like this:
AAABCAAABAAAAAA
All screwed up. Now if you have a entire file system that is compressed and you loose a couple bits then you could loose many many files of lost information.
Also recovery would be a pain in the rear, since you would have to know were to start decompressing stuff.
Another thing that sucks about compression is when you use it into backups.
Say you use the unix tool "tar" to copy entire contents of a home directory into one big file. You loose some bits out of it, then you only loose a little bit of information out of one file. However if you compress it using gzip to make a "tarball" then if you loose a little bit of information then the WHOLE THING is trashed.
So a much better thing to do for backups would be to make one big file, split it up into smaller files then compress the smaller files individually, then you decompress them, join the files together, then untar it into a proper directory system.
that way if you loose a few bits, only that small section of the directory tree is trashed, the rest of the data would still be easily recoverable.
Also another reason you don't do it is because data that can be usefully compressed is already compressed.
Jpeg images, movies, audio files, anything big is almost always compressed. The only thing that realy saves space during compression is text and binary uncompressed files and those don't realy account for much space anymore.
Go zip up a mp3 song or a jpeg image, you'll see that little if any space will be saved. Also sometimes you end up with slightly larger files when they are compressed!
