Originally posted by: BrokenVisage
Originally posted by: MathMan
I have the Comcast DVR and love it...although it can be a bit buggy at times.
Recording is really as simple as navigating to any program in the program guide, and hitting the record button.
One of the issues people have noted with this box is that if you set something to record when the cable box is off, the cable box will automatically turn itself on right before recording-- but will mute the audio while it records. Some people think of this an an actual feature (in case your DVR is hooked up to a home stereo)... but it can be frustating if you try to watch TV on another channel since there is no way to turn the audio back on except to powercycle the box (which would cancel your recording).
My solution to this is to just never turn off your cable box-- but you can also repgrogram a key on your DVR remote that will act as a mute/un-mute button for the cable box. You can also re-prorgram another button to act as a 30-second skip button-- which works great for cutting through commercials (just hit the button four times)...
Yup, I have the DCT6412 Phase III DVR and experience all of that, and the 30 second skip is very useful!
Originally posted by: PlatinumGold
not true.
what happens is the cable box mutes.
solution, take the remote, click on "Cable" then click on "Mute" voila you have sound.
that's all i've ever done and it's always worked.
No he's right, I can't just hit Cable and unmute it like that, atleast not with the provided controller.
