- Feb 23, 2000
- 416
- 0
- 0
i'm reducing the sound of my case by lowering my 2x 80mm fans to 5 volts & also lowering the 2 fans on my cpu to 5 volts. is this safe as i'd only switch them to 5 volts while browsing & desktop work. when i play games i'll switch them all back to 12 volts. i think it should be ok if the cpu goes up a couple of degrees c. my temps a currently room temp: 24c case temp: 25c cpu temp: 31c
let me know how much your temp went up on the cpu running it at 5 volts.
