is Antec 350Watts enough for today's system?
netjack
223
I wanted to know if 350Watts is enough for today's system (xp2000+(not overclocked), 512mb of PC2100, 2 7200 rpm drives, dvd-drive,cdrw, floppy, soundcard,ethernet,geforce ti4400 128mb, 2 case fans?
Is the antec server chassis' size in between the sizes of a mid-tower and full-tower antec case?
Is there a true power 350W antec ps?
Anyone have any opinions on the antec smart power 350W ps? You can pick them up at best buy for like $35.
thanks for all the info.
Sukhoi
15,349
The TruePSUs come in 330, 380, 430, 480, and maybe 530 watt versions. No 350. But the True330 is going to be better than a regular 350 anyway.
rocketbubba
1,935
I'm not an expert on Power Supply issues, but I can tell you that I've had no problems running my system with an Antec 300W PS. My system is a cheapo mid-tower, T-Bird 1.4, Taisol hsf, 3 case fans, 2 sticks of sdram, video card w/fan, CD-RW, DVD, 7200 HD, and Floppy. Hope that helps.
LED
6,127
Yes if it's an Antec or any other good quality PSU although some MoBo's are finicky
Zim Hosein
Super Moderator | Elite Member
65,387
406
netjack, I'm running my system w/ a 300w PS and don't have any power issues, hope this helps :)
olds
50,122
778
Last time I checked AMD's site, they recommended the 400 watt for an Antec PS.
Chu
Banned
Jan 2, 2001
2,911
This is what my system had before forcing me to upgrade from an Antec303X Power Supply (300W):
Pentium 4 1.6 ghz @ 2.2 Ghz @ 1.5v
2x 7200 RPM drives (Western Digital 120gb Special Edition, IBM 75GXP 45gb)
1x 5400 RPM drive (Maxtor 7200 rpm 40 giger)
2x Optical Drivers (Toshiba DVD/CD reader, LiteOn CD-RW)
Note each of the above drives as on its own IDE channel. Your IDE cables are each rated at 5W . . . hense another reason people have been pushing for serial ATA
ATI Radeon 64MB DDR VIVO
2x Maxtor IDE Cards (Promise rebadged)
Sound Blaster Live!
Winmodem
Ethernet
5x 80mm Case Fans
2x Other fans
Printer Cable (these use more power then you think)
3 random USB devices (kb/mouse/joypad).
So what pushed it over the edge? One more hard drive :) My system grew completly unstable after adding a 4th drive to the mix, but I recently upgraded to a 400W antec and haven't had a single crash since.
fr
6,408
I have a 250W power supply running 5 PCI cards, 1 AGP, 4 hard drives, 8 USB devices, and 2 CD drives. No problems.
