There is a difference between digi co-ax and regular rca cables. like it was mentioned digi co-ax cables, depending on application, have a constant measured resistance. the most common being 75ohm. but for going just from your sound card > receiver, if it sounds ok to you it's probably gonna work just fine. but if you are doing something like a DAT or MD deck to your pc, you will for sure want the correct digi co-ax line.
j
