Is AMD 960K Athlon Excavator likely to beat intel 2500K sandy bridge?
NostaSeronx
3,701
1,230
Have we even confirmed that there will be a high-frequency version of the Excavator cores? Excavator is meant to be made using High Density Libraries- these are intended to significantly improve power consumption, but at a cost.
Excavator on SOI has been confirmed to be >4 GHz on the highest 65W SKU.
szatkus
16
Depending on what AMD did with the "Excavator" architecture. AMD could be able to improve performance with little effort.
The changes with Steamroller's front-end allows for an evolution from MCMT. This evolution is specifically called Clustered SMT.
MCMT;
http://i.imgur.com/v3CTSnd.png
1st Gen CSMT;
http://i.imgur.com/uRI6Byp.png
(FDL -> Forwarding Logic, this removes dependencies between clusters sharing a module. This will improve performance when running SPMD in regards to integer. The FPU is already SMT, so the improvement in the FPU will need to come from AVX2 and FP256.)
Clustered SMT is far from "little effort".
inf64
3,863
4,539
Nowhere... Also >4Ghz is a pipe dream. Even SR cannot clock past 4Ghz (stock speeds).
Maximilian
12,604
15
Come on guys stop with the AMD vs Intel crap.. both are great Cpu's and this isn't 2000-2001 any more and anything with 4 core is more then enough for 90% of users. We all know 860k-960k is no where near a 2500K and its not meant to be.Its like comparing a Dodge Caravan to a Lamborghini..Both vehicles will get you to where you need to go but the more expensive one will get you there a little bit faster.Not every road is gonna let you go 120Mph though just like your not going to be able to tell the difference in every program between either cpu..Maybe in gaming or video encoding but thats about it..
Oh man this post has it all.
- Come on guys lets all get along and not discuss anything viewpoint
- Claim that one chip was never meant to be like another chip so its not fair to compare or whatever
- A car analogy
Dude seriously?
People like to discuss/argue, deal with it.
One chip is better than the other regardless of what its meant to be, deal with it.
Car analogies suck, deal with it.
NostaSeronx
3,701
1,230
They are capable of introducing both forms with little effort without causing a huge change. It is essential adding a macro/micro-op cache level of difficulty.
Front-end level because of the separate decodes.
Execution level because of the proximity of the cores.
For execution level;
What AMD would be adding is a Forwarding Retire Queue or upgrading the current Retire to be able to have Forwarded instructions. Then, Forwarding Logic to scan the Retire Queue for dependencies between both cores. If there is a dependency, the given instruction is shifted to another core, where it will be resolved quicker.
Where, precisely?
AMD Leads on Linkedin.
Excavator can be on only two nodes after 28-nm SHP; 28-nm SOI or 20-nm LPM/SOC. Puma+ being on a 28-nm node is hinting at 28-nm SOI.
chrisjames61
721
446
I seem to remember you saying your overclocked 760K would match or even beat an i5 of recent vintage. When in all reality there hasn't been an i5 made that isn't more than a match for a 760K stock or otherwise.
szatkus
16
Sure, sounds easy. Getting it work and debugging would rather be new-microarch-level effort :>
Links :D
NTMBK
10,297
5,289
Bit of an exaggeration there. ;) Something like an i5-650 is clearly slower.
JumBie
1,645
Lies? how stupid can you even be. I got double the FPS of my old Phenom II X2 with my previous intel dual core pentium G haswell which is still unplayable since the old phenom II X2 is around 9 FPS min in many many situations. Totally unplayable
Maybe do some research next time before looking like an idiot making claims about my "lies"
dual cores STINK in these 64 player maps with high tech Engines like frostbite 2 and 3. Mantle tries to help but its still pretty bad, the haswell pentium G3220 was trash which is why I got rid of it. Or wait you must be one of those idiots who look at Single Player benchmarks ROFL
Just imagine 3 years later after the release of battlefield 3 and people are still this retarded to pointing to single player benchmarks and saying ow look BF3 runs smooth on dual cores guess thats that.
Ow wait nobody buys these games for single player neither do they play single player.
Find another way to make your point without calling people idiots.
esquared
Anandtech Forum Director
I don't know about anyone else but I play Battlefield 3 on a G3220 with a 560 ti on 64 player maps, 1080p@high and my fps stays within the 50-80 range, absolutely playable for me.
Fjodor2001
3,989
440
What you guys think will happen here with excavator in terms of single and multi threaded CPU performance?
AMD likely to reach sandy bridge or ivy bridge performance finally?
Point is that it does not have to surpass 2500K to be successful. It only needs to get close to 2500K level of performance, which is not unlikely.
If it can get close to 2500K level of performance it can be a real success if sold at a lower price.
Justification: Have you noticed how Intel no longer discounts older CPUs much? Some years ago Intel would drop the price by 20-30% or so on older CPU generations when they introduced a new one. But the reason they are no longer doing that is that the newer generations are not that much better than the old ones. So if people could get a 3570K for 20-30% less than 4670K, then 3570K would sell much better, 4670K would not take off, and Intel's profit would be less. And if you could get a 2500K for 30-40% less than 4670K the situation would be even worse for Intel. So Intel doesn't want to go down that route.
But assuming AMD can get close to 2500K level performance with Excavator, at a distinctly lower price than 2500K (or 4670K), then Intel's pricing strategy may break down.
Yuriman
5,530
141
Considering how much AMD is hurting for cash, they'll likely charge more if it performs better, rather than forcing Intel to lower their prices to compete.
$190 7850K's, anyone?
geoxile
327
25
Have we even confirmed that there will be a high-frequency version of the Excavator cores? Excavator is meant to be made using High Density Libraries- these are intended to significantly improve power consumption, but at a cost:
http://www.anandtech.com/show/6201/amd-details-its-3rd-gen-steamroller-architecture/2
So an Excavator core may not be able to clock as high as a Steamroller core. I expect that we will see Kaveri stick around on the desktop.
Lower clock from HDL but offset by higher performance due to SOI? Who knows. Given they're saying 30% higher perf/watt, XV should consume about 25% less power (1/1.3). Given that FD-SOI is supposed to offer 40% higher performance or something it seems like they have room to clock higher than SR. I guess we'll see though.
http://www.hardcoreware.net/wordpress/wp-content/uploads/2014/07/amd-carrizo-slide.jpg
inf64
3,863
4,539
XV is on the 28nm process as SR and Puma+. We have an official AMD slide from last week.
Burpo
4,223
473
Don't confuse him with facts.. Maybe he doesn't have a GTX 560ti ():)
inf64
3,863
4,539
No, that says it's on a 28nm node. Not the same process.
They are using HDL that is affecting the frequency scaling drastically. XV core would be lucky to clock anywhere near SR no matter what process changes they implemented.
edit:
Kaveri is built on GF 28shp(super high perf.) while XV appears to be on GF28A which is standard bulk silicon node.
geoxile
327
25
HDL should be a circuit layout. Meaning it's part of the chip design, not the fabrication. FD-SOI has advantages of its own that will affect the performance of the final product.
SHP is a bulk node.
http://hothardware.com/Reviews/AMD-Kaveri-Update-A107800-APU-Review/
Using this 28nm SHP process, which employs bulk silicon, forced AMD to sacrifice some CPU frequency at the high-end of the TDP scale, but with better power characteristics at the sweet spot.
mrmt
3,974
Interestingly enough AMD isn't updating Mullins for the Puma+ core. It seems that Mullins isn't gaining traction at all, and that we're going to have another zombie product line, like Vishera.
Justinbaileyman
1,980
249
I'd like to see you prove that.. Also I see you are stalking me from other forums and from other sites, think I will have to have a word with an admin.
And for your info I am sure what was said in the other forum was my 760K at 5Ghz was faster then a "STOCK" "FIRST" "GEN" "i5" "SOCKET" "1366"...... If its not prove me wrong. I dont care what you have to spout around kid show me the anandtech benches then come back and post some more with your foolishness of twisting my words.Not that this has anything at all to do with this thread.Sorry to the op just wanted to get this out.
NostaSeronx
3,701
1,230
Now for the SOI conspiracy for Carrizo with iGPU disabled, section of this thread;
Sub-note; SOITEC expects 1.075M(million) wafers to be used per year by 2017 for 28FD.
Enigmoid
2,907
31
This 100%.
Intel has a lot of budge room on its margins and binning while AMD doesn't.
Every single intel consumer chip ships with a fully functional igp with the full number of EUs. Quads with core defects are discarded. Only 'perfect' chips are sold.
Justinbaileyman
1,980
249
This 100%.
You know I've been thinking the same thing.How soon before we start paying more for AMD's offerings??
