- Feb 28, 2016
- 2
- 0
- 6
currently i'm in an ADSL 2+ connection with 7 mbps down and 1 mbps up, since my area will be getting fibernet connection soon i brought this router ,tp link archer c20i so that i don't need to buy a new one if fibernet connection arrived in my area . now at present i have connected the router with a normal modem for ADSL connection but now unfortunately the wired modem is not working properly and i'm planning to buy a new one .i have two choices buy tp link td-w8968 v4 or a used wired modem ,the advantage with tp link td-w8968 v4 is that it supports both DSL and ADSL connections but i already have a router . so if i buy tp link td-w8968 v4 i should sell my current tp link archer c20 i, my question is which is better tp link td-w8968 v4 or the tp link archer c20i , i know that tp link archer c20i supports wireless AC but is it useful for a 40 mbps or a 60 mbps connection ? my both laptop and phone supports 5ghz band with wireless AC and there are about 5-6 2.4 ghz users in my neighbouring area and zero 5 Ghz users . so which should i go tp link td-w8968 v4 or buy a used wired modem and hook it with the tp link archer c20i?
