- Oct 20, 2014
- 7,340
- 6,124
- 136
I've never supported the idea of getting a CPU and then upgrading it. If you ever want to play modern titles you will need an i5. It isn't optional. And you won't save money by upgrading later as Intel doesn't drop prices. I'd compromise and get an i5 4690 non K and an H97 board with the best GPU you can afford with whatever is left.
I have an H81 board, and no reason to get an H87 board right now, as PCIE-2.0 and PCIE-3.0 offer no difference in performance with even high end cards. I think it would be a while before I'd ever consider having three SSDs also, so the two SATA6 ports and two SATA3 ports are fine for me since a 7200 RPM mechanical drive uses about a third of the SATA3 bandwidth. I'm not even looking at one SSD anytime soon, as the cost still is way over mechanical drives, you have to reserve maybe 20-25% of the space on them for empty space or performance degrades, and I don't care much about booting into Windows in 8 seconds vs 15 seconds. I do think i5-4590 is the CPU I'm most likely to get though.
