Is a HS and Fan on an non-OC Athlon CPU enough cooling?
yuccamonster
Here is a novice question and I couldn't find an answer
on the forums. I am putting together a system and have a
HSF on an Athlon 1.2 GHz CPU. I don't intend to OC and its
on a MSI Turbo-R MB.
Do I need to get cases fan(s)or is this enough cooling.
Thanks,
TSB:D
Imaginer
8,076
Usually, one case fan in the front plus the fan on the Athlon approved PS and a good heatsink and fan is adaquate.
enginjon
659
If your computer is in a cool room, then usually the PS fan is enough. But if your room is warm or hot, you may, like Imaginer said, put a fan up front for intake. If you have mounting spots in your case, and notice your temps maybe a little igh, I would go ahead and put in a case fan or two.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
Go to the source:
HERE
Basically, they recommend an exhaust fan in the rear behind the processor and an air intake down low in the front as a minimum.
More cooling won't hurt, but you don't need noisy high flow fans, either.
TSB
Thanks for the advice. I put a case fan in and a second fan at the front plus the
HSF on the CPU and am running a 1.2 (266) athlon around 55C. The second fan dropped
the CPU temp around 5C so was worth putting on.
TSB:D
Iphis
Banned
Mar 1, 2001
257
Having case fans for intake and exhaust are good but sometimes a stock heatsink will not allow for proper airflow. The processor you have will run hotter than lower mhz processors even without being overclocked. It wouldn't hurt to get a better heastsink and fan for more airflow directly over the processor. This is truly only an opinion, so I don't upset people, I just think safer is better than sorry. I just don't like the idea of using the bare minimum when it comes to keeping that thing cool. Noise is not always a problem just because you upgrade to a better heatsink and fan. Shop around, look at airflow in CFM's, and check for a decibel level rating.
