Is a blade grinder really that much worse than a burr for pour over coffee?
Status
Not open for further replies.
preslove
16,754
64
My sister just bought me a chemex pour over for christmas. Now I'm looking at grinders. If I'm just going to use the chemex, is a burr grinder really all that necessary?
Born2bwire
9,840
It's never necessary, it's just nice to have and is better at making a more consistent grind. With a filter like a chemex, I don't know if you would appreciate it much. I have a French Press so a consistent grind keeps sludge out of my cup and those with espresso machines need to get a very fine and consistent grind that would be difficult from a cheap blade grinder.
disappoint
10,132
382
Mortar and Pestle. Be a man.
NetWareHead
THAT guy
Aug 10, 2002
5,847
154
A burr grinder is usually preferred to coffee grinders were you deposit the beans in a sealable chamber with rotating blades (kinda like a food processor). These grinders heat the product up via friction, something usually undesirable when grinding coffee and spices. These grinders are also harder to get a consistent grind.
Burr grinders achieve a much more consistent grind by virtue of forcing everything through a pre-set grinding space.
CA19100
634
13
If you're using paper filters, you can get by with a blade grinder, although the coffee will taste better with a burr grinder. (Either one will still taste better than pre-ground or store-ground coffee, however!)
If you're using one of those permanent metal filters, or using a French press as Born2bwire is, you absolutely don't want to use a blade grinder. With one, you're guaranteed to get sludge in your coffee from the smaller re-ground coffee pieces that can slip by the filter holes.
vi edit
62,484
8,344
I would say even more important for that type of brewing. You more than likely will want control over the type of grind based on tastes. A burr grinder will let you do a fine vs course ground and do it consistently each time.
blackangst1
22,902
2,359
Yes. This.
sygyzy
14,001
4
Agreed. Consistency is key.
Status
