Currently I have a 2.4/533 FSB P4. The motherboard is based on Intel 865G chipset, so it supports 800 Mhz FSB. It can take Socket 478 Prescotts too, but the case is a small form factor with only a 240 Watt PSU and is rated as 2.8 Ghz max in terms of cooling (In-win L545).
I don't game at all, but there are some high-definition MPEGs that stutter. Like those 4GB movies, you know. Most of them still play fine, but there are more and more that don't. The video card is a Geforce 6200 128 megs so it doesn't really accelerate high definition. Before anyone asks, the PC has 1GB of dual-channel DDR400, so too little RAM isn't the case.
Do you think if I go 800 FSB NW it will play all high-def movies smoothly?
