hey all, im trying to overclock my new PhenomII X6 1100t, and i installed it with a Big Typhon (much better than stock heatsink) and some Arctic silver 5, but under load in Prime95 with just 1.35vcore its hitting 67c (on the core)!!!! It goes from 40c @ idle, then to 50s, 60c, & then to 67c, & back down to 62c under load in Prime95. Granted its summer here, room temp is 28c, but the X3 720 it replaced NEVER reached those temps (maxed at 53-54c but NOT prime95, just playing FPS games) . I read the Thurbons run hotter but this is insane. Only Prime95 using all 6 cores pushes it up to 60+, no other programs push it that hard. I'm scared its because the Thermal paste didnt settle, or maybe i mounted the heatsink wrong, although if it were the latter im pretty sure i'd be getting BSOD every few minutes, no? or is it just Prime95 pushing it to its limits?
I googled it and AMD states 62c is the maximum safe temp on the core, and 72c+ is the danger zone (so whats everything between 62c-72c???? lol the grey area?) . Thing is im not sure if the read out is indeed the core, its speedfan that im using, and it says "core" is 62-63c, but 2 other temps at top are 44 & 59 ("temp 1" & "temp 2"). with my X3 720 that was accurate, so i have no reason to assume its not with the X6.
Mind you in FPS games it never passes 50c, Prime95 just makes it skyrocket though (im guessing this is because the FPS games (Crysis, C.O.D.: Modern Warfare 2) only use 2 cores max, whereas P95 uses all 6. EDIT: just encoded a movie from AVI to MP4 and it used all 6 cores, and yes the temp went up to 62c, so yes it does happen in the real world.
What do you guys think?
