hi guys, this is my first post here, so plz help me out if u can.... I sent the following email to MSI.....it explains everything:
To whom it may concern,
*Please answer the following question in full detail*
I have found out that the MSI K8N SLI Platinum motherboard requires a -5V pin supply in the power supply, and not many power supplies coming out today have this..........i investigated this matter on the MSI forums, and found out that only the earlier models of the motherboard required this, and not the newer models coming out today,.......... after more investigation, i have found out that the taiwan version of the motherboard still requires the -5V pin supply, but the USA version does not require it.....although this is not 100% official, but this is a possible proof offered on the MSI forums.......
the MSI USA website:
http://www.msicomputer.com/product/p_sp...p?model=K8N_Neo4_Platinum/SLI&class=mb
MSI Taiwan website:
http://www.msi.com.tw/program/products/mainboard/mbd/pro_mbd_detail.php?UID=641
if you look on these pages carefully, only the taiwan page says right at the bottom:
For this model, you must use a Power Supply which has a -5V pin supply.
the USA page does not state this......another possible proof i found myself is that, MSI USA is offering a free upgrade to MSI K8N SLI Platinum motherboards purchased in USA.......as far as i know, this offer is not available in taiwan:
http://www.msicomputer.com/msiapps/SLICampaign.aspx
i found out that the -5V pin supply is required for the onboard 24 bit creative audio chip......if the -5V pin supply is not available, there will be no audio, unless u fit in an extra PCI audio card........
all this means that the USA version of this motherboard is different from the taiwan version..........i am in Pakistan, and the version sold here through MSI distributers is imported from taiwan.....so it must need the -5V power supply.......
what i want to ask you, is if you can confirm this, through any means necessary.........i need advice on this.......
I need to kind out exactly if the -5V pin supply is required or not, and in which models it is required, and for which models it is not required...
I am requesting again, that you please answer this question in full detail, and not just give an objective answer.
regards,
Ahmad
MSI Taiwan website:
regards,
Ahmad
