If you're not sure what your CPU's max temperature is, you can look it up
here. Note that overclockers often define "too hot" at lower temperatures because transistors slow down at higher temperatures, so they don't OC as far at higher temperatures.
IIRC, figuring out the number for a specific processor on models with a range of max temps requires something described
here.
Disclaimer: I'm not speaking for any companies.
